wmickens
Nov 10, 2020Aspirant
RBR20 lag spikes
This is very frustrating. I have an Orbi RBR20 that when I ping the router itself from two different machines (Linux and Windows) and a cell phone i get occasional lag spike that ranges from 60ms to as high as 1200ms. Pinging local IP addresses when the router is no more than 20 feet away should not produce such lag spikes. I started noticing it more frequently when playing my online game and I would get a brief disconnect. It would reconnect but sometimes it would take a few seconds. Both PCs are connecting wirelessly and the Orbi has been rebooted numerous of times.
Not to mention sometimes the web interface is slow to load or even won't display at all (500 internal server error). Before I replace this and the satellite I have for extended coverage what can be done to correct this
What modem are you connected to?
What firmware is on the router? And the satellite(s)?
Have you tried turning off the satellites and seeing if you get the ping spikes just running the router?
- wmickensAspirant
It is a Spectrum modem but I'm only pinging the internal IP address.
Model Name Device Name Current Version Status Router RBR20 RBR20 V2.5.1.16 Satellite RBW30 Sat-one V2.6.1.6 With just the router I was getting the same spikes.
Here is a snippet of the ping to the router:
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Reply from 192.168.1.1: bytes=32 time=5ms TTL=64
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
Reply from 192.168.1.1: bytes=32 time=18ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=10ms TTL=64
Reply from 192.168.1.1: bytes=32 time=7ms TTL=64
Reply from 192.168.1.1: bytes=32 time=12ms TTL=64
Reply from 192.168.1.1: bytes=32 time=323ms TTL=64
Reply from 192.168.1.1: bytes=32 time=8ms TTL=64
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64
Reply from 192.168.1.1: bytes=32 time=16ms TTL=64
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64Here is the stats of the ping I just ran:
Ping statistics for 192.168.1.1:
Packets: Sent = 579, Received = 579, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1ms, Maximum = 1796ms, Average = 33ms- plemansGuru - Experienced User
If you're getting this with the satellite powered off, it isn't the satellite.
have you tried a factory reset on the router?
when you reinstall it, do a clean install (not from backup).
Make sure to leave traffic monitoring, access control, parental controls all disabled.
- mlodickAspirant
I'm having the same problems and it's driving me nuts. I just ran 100' of ethernet cable so the backhaul is wired now, I'm sitting 10 ft from my wireless access point, and I still get the same lag spikes (and timeouts), just pinging the router itself.
64 bytes from 192.168.177.1: icmp_seq=26 ttl=64 time=1.980 ms
64 bytes from 192.168.177.1: icmp_seq=27 ttl=64 time=1.858 ms
64 bytes from 192.168.177.1: icmp_seq=28 ttl=64 time=1.945 ms
64 bytes from 192.168.177.1: icmp_seq=29 ttl=64 time=1.242 ms
64 bytes from 192.168.177.1: icmp_seq=30 ttl=64 time=7.518 ms
64 bytes from 192.168.177.1: icmp_seq=31 ttl=64 time=1.654 ms
64 bytes from 192.168.177.1: icmp_seq=32 ttl=64 time=2.013 ms
64 bytes from 192.168.177.1: icmp_seq=33 ttl=64 time=3.644 ms
64 bytes from 192.168.177.1: icmp_seq=34 ttl=64 time=4.976 ms
64 bytes from 192.168.177.1: icmp_seq=35 ttl=64 time=2.309 ms
64 bytes from 192.168.177.1: icmp_seq=36 ttl=64 time=17.544 ms
64 bytes from 192.168.177.1: icmp_seq=37 ttl=64 time=2.398 ms
64 bytes from 192.168.177.1: icmp_seq=38 ttl=64 time=3.506 ms
64 bytes from 192.168.177.1: icmp_seq=39 ttl=64 time=9.223 ms
64 bytes from 192.168.177.1: icmp_seq=40 ttl=64 time=27.516 ms
64 bytes from 192.168.177.1: icmp_seq=41 ttl=64 time=69.829 ms
64 bytes from 192.168.177.1: icmp_seq=42 ttl=64 time=5.740 ms
64 bytes from 192.168.177.1: icmp_seq=43 ttl=64 time=171.762 ms
64 bytes from 192.168.177.1: icmp_seq=44 ttl=64 time=34.243 ms
64 bytes from 192.168.177.1: icmp_seq=45 ttl=64 time=4.469 ms
Request timeout for icmp_seq 46
Request timeout for icmp_seq 47
Request timeout for icmp_seq 48
Request timeout for icmp_seq 49
Request timeout for icmp_seq 50
Request timeout for icmp_seq 51
Request timeout for icmp_seq 52
Request timeout for icmp_seq 53
Request timeout for icmp_seq 54
Request timeout for icmp_seq 55
Request timeout for icmp_seq 56
Request timeout for icmp_seq 57
Request timeout for icmp_seq 58
Request timeout for icmp_seq 59
64 bytes from 192.168.177.1: icmp_seq=60 ttl=64 time=763.198 ms
64 bytes from 192.168.177.1: icmp_seq=61 ttl=64 time=60.923 ms
64 bytes from 192.168.177.1: icmp_seq=62 ttl=64 time=79.584 ms
64 bytes from 192.168.177.1: icmp_seq=63 ttl=64 time=112.959 ms
64 bytes from 192.168.177.1: icmp_seq=64 ttl=64 time=150.602 ms
64 bytes from 192.168.177.1: icmp_seq=65 ttl=64 time=4.830 ms
64 bytes from 192.168.177.1: icmp_seq=66 ttl=64 time=6.664 ms
64 bytes from 192.168.177.1: icmp_seq=67 ttl=64 time=7.855 ms
64 bytes from 192.168.177.1: icmp_seq=68 ttl=64 time=17.992 ms
64 bytes from 192.168.177.1: icmp_seq=69 ttl=64 time=6.075 ms
64 bytes from 192.168.177.1: icmp_seq=70 ttl=64 time=2.109 ms
64 bytes from 192.168.177.1: icmp_seq=71 ttl=64 time=5.273 ms- plemansGuru - Experienced User
Try downgrading the firmware a version (or 2), factory reset and do a clean (not from backup) install. Disable auto-update.
Don't change anything from default other that whats needed to get online.
Then test ping.
