UserUserUser
Jul 23, 2020Aspirant
RBR20 NAS only visible near satellite it's plugged into
Folks,
My Seagate network storage (connected to one of the satellites via Ethernet cable) is perfectly recognized and working, but only if I'm in the range of that satellite. It doesn't show on the list of available network devices if I'm near any other satellite. Internet connectivity works just fine, and my network printer (connected over WiFi) doesn't seem to have any problems.
Any feedback would be appreciated.
What happens if you connect the NAS to the RBR and then connect to the RBS? Can you still see the NAS then?
- UserUserUserAspirant
... and I don't see any difference in behavior if I connect anything via network cable to a satellite or to the master router - I cannot get to it once I'm not in the paticular tower's range, but Internet and everything connected over WiFi still works.
Well, I don't see the firmware version I just posted - just in case it got lost: the firmware version is v2.5.1.16
IF this doesn't change anything, I would make contact with NG support about this.
