Latchland
Apr 18, 2020Aspirant
RBR20 on NBN Fttp without isp modem
Hi all I currently have an Orbi RBR20 and one satellite connected and working. I'm wanting to remove the isp modem router from the equation and run the orbi alone so that all devices use it rather ...
Retired_Member
Apr 19, 2020I have an RBR20 on nbn FttP with Aussie Broadband. It works fine. Aussie Broadband don't require a VLAN on the WAN port. Your ISP may. The ORBI supports this, but I can't comment on how to configure it. Someone on forums.whirlpool.net.au would be able to assist with questions about specific ISP configuration on the Orbi.
RBR20 running V2.5.1.16 firmware. It also worked with V2.3.5.38 firmware which I upgraded from a couple of days ago.
Latchland
Apr 20, 2020Aspirant
Thanks for the info!
