phidgety
Jan 26, 2020Aspirant
RBR20 ORBI AC2200 - connected, but in "Settings" it says there's no IP address
I'm using an iMac.
Just got a new Orbi to replace my dead Nighthawk, installation was a snap — both the base, satellite, and my printer are connected, but in "Settings" > "Network" while it shows the Orbi is connected it also says "No IP Address".
Do I need to worry about this?
Can you take a screen shot and post it?
Otherwise, "everything works"?
- phidgetyAspirant
Thanks CrimpOn,
Strangely, when I returned to the "Settings" screen, it no longer mentions a missing IP address, it merely says, "Connected".
I'm amazed at the speed of the community's answers, as well as at the thorough knowledge you all have.
Phill
- phidgetyAspirantI’m sorry, I intended to write saying it turned out my Nighthawk died so I bought an Orbi and it was simple to set up. Now our internet is working great. Thanks for your help.
. - phidgetyAspirantI’m sorry, I intended to write saying it turned out my Nighthawk died so I bought an Orbi and it was simple to set up. Now our internet is working great. Thanks for your help.
