Stevevoisey
Jun 25, 2020Initiate
RBR20: periodic internet outages
We bought a 2-pack (RBR20 + RBS20) 2 months ago. Our connection speed is now exceptional connected to the fibre router. We really like the product. We moved to a new house four weeks ago and bought another RBS20.
But all this time our connection has dropped off once or twice a week. It's down for about 15 minutes. It never used to happen with our previous system (Airport Extreme).
Do you have any thoughts or simular expreiences?
1 Reply
IWhat is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
