pkbhas's avatar
pkbhas
RBR20 Satellite when enbled causes intermittent internet
when the satellite of RBR20 is switched on, there will be frequent disruption of interrupt connection.
When its left switched off,  and have only the main router, then there will be no intermittednt issues in internet connection.
The satellite is connected to a server on ethernet cable. Thats the only wired connection on satellite.
Following the advices on community tried updateing to altest firmware. but no luck.
Any advices?
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the Mfr and model# of the ethernet switch in the configuration?
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
    • pkbhas's avatar
      pkbhas
      Firmware Version: V2.5.1.16
      AP mode is ON.
      modem model:E31T2V1
      Size of home: 3000 sqft
      Distance between router:
      Main rounter in 1st floor.
      Satelite in 2nd floor at a vertical height of 10 ft and horizontal diatance of apx: 15-18 ft.
      • FURRYe38's avatar
        Your modem model doesn't have a built in router or wifi. IF you have your Orbi in AP Mode, this needs to be changed to router mode as there needs to be a router in between the modem and your wifi devices.
