Efdo's avatar
Efdo
Initiate
Apr 04, 2020
RBR20 slow connection to PC (Ethernet & WIFI)
Hi - struggling with the following problem:
I have gig service from Rogers, with a Hitron Coda-4582 modem/router.  I have disabled the gateway function.
Have a wired connection going from the Hirtron to the RBR20, firmware V2.3.5.30, in router mode.
Then a wired connection from the RBR20 to a d-link 8 port switch.
The PC is then wired into the d-link
All lights indicated Gig connections.   Network adapter in PC is a Realtek PCIe GBE Family Controller - it shows 1.0 Gbps under status.
Speedtest.net showing download 14-16 Mbps, upload 25-30 Mbps.  (similar speeds happens if I switch the PC to WIFI)
If I skip the d-link switch and connect the PC directly to the RBR20, same slow speeds
The kicker is - If I connect the PC directly into the Hitron modem I get 900-950 Mbps download, without changing any setting or rebooting anything.  Also - all my wireless devices are fine...my iPhone X regularly gets 350+ Mbps speeds.
Have rebooted dozens of times.  I'm convinced everything worked when I first bought the Orbi.  Noticed the slower speeds since working from home the last couple of weeks.
  • FURRYe38's avatar
    Power OFF the ISP modem for 30 seconds, then back ON.
    Factory reset the RBR and setup from scratch, walk thru the setup wizard.
    https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
    https://www.youtube.com/watch?v=ePZSc7vnRlQ
    Be sure to NOT enable Circle or Armor or QoS or Traffic Meter.
    Test the speed using Ooklas installable speed test app on your PC.
    Try a different PC to compare speeds as well.
    • Efdo's avatar
      Efdo
      Initiate
      OK - so did the factory reset and things look better; however, I do not see a QOS selection in the Orbi menu (everything else is disabled Circle, Armor & Traffic meter).
      I tried both the webpage and app versions of speedtest:
      APP:
      • Ping: 13ms / Download: 934Mbps / Upload 27Mbps
      Webpage:
      • First try, Ping: 5ms / Download: 15Mbps / Upload 23Mbps
      • Second try, Ping: 10ms / Download: 884Mbps / Upload 27Mbps
      • Third try & subsequent, Ping: 5ms / Download: 13Mbps / Upload 26Mbps
      Loading websites definitely happening faster...so thank you!
      • FURRYe38's avatar
        Glad the reset worked.
        Enjoy. :smileywink:
