Mannyk74
Jul 04, 2023Aspirant
RBR20 some IoT devices do not work anymore.
Hi there,
I have 5 or 6 Tuya devices that I have flashed with Tasmota. They are from different manufacturers. Suddenly, a few days ago, I stopped being able to control them. I can find them on the network, and they are all pingable. But I cannot access them on my browser either. I just get a “this site can’t be reached” error. or ERR_CONNECTION_REFUSED.
If it were only one device, then I would have thought it was the device. But the fact that a few devices have failed makes me think it has to do with the router.
Sonmething to contact the Mfr of these IoT devices about.
- Mannyk74Aspirant
Thanks for your response.
Turns out it was a problem with my homebridge server. It just needed restarting.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
