Road69runners's avatar
Jun 05, 2022
RbR20 will not factory reset to default
Hi all, i forgot my password to logon to update my router and need to reset it to factory defaults. I press the paper clip in until the power light blinks amber. It blinks like that for a few seconds then goes right back to green and my current network names show up in wifi. How else can i reset it? Thanks for the help.
  • Press the reset button for 15 seconds then release...Does this bring up the setup wizard seen at 192.168.1.1 with a wired PC connected to the back and using a web browser? Be sure to clear out all browser caches.
