Bchua's avatar
Bchua
Follower
Jun 25, 2020
RBR20 with 2 satellites
I am running my Orbi now for at least a month to two months now and I am experiencing disconnecting from internet it will just go offline and I have to wait and it will come online. My firmware version is V2.5.1.16.
Can someone help?
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
