CaptainBroach's avatar
Dec 03, 2019
RBR20
I just wanted to say that after an hour getting bumped around this "Support" site to resolve my problem and also being unable to access the Netgear Chat Support I'm authorized by my purchase, I'm pretty damn discussed with Netgear.  I can neither find a solution nor find a way to get to a solution.
I have a functioning Orbi network that my apple devices all find no problem, but neither of my HP Laptops running W10 can sign on.  Just stopped being able to access the network after doing so successfully in past.
This support site is about as useful as telling me to find a penny in a football field sized pile of leafs
  • Retired_Member's avatar
    Retired_Member
    Dec 03, 2019
    CaptainBroach wrote:
    I figured this out myself by pushing enough buttons and wipping out all my wifi settings on earch laptop then started from ground zero.  seems to be working for now.
    Enjoy :smileyhappy:
  • FURRYe38's avatar
    Be sure to have the Windows laptops forget any prior saved wifi configurations or profiles.
    Be sure the WiFi adapter drivers on the windows laptops are fully updated.
    Do you only have the RBR20, no satellites?
    WPA2 and AES currently set? What happens if you temporarily disable WPA on the RBR and then connect the laptops? Set back to WPA2 and AES after trying this.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Retired_Member
    What do you mean ..."neither of my HP Laptops running W10 can sign on."
    Are these laptops trying to login to your network via wifi or wired?
    Any changes to your network password (perhaps to accomadate Apple)?
    • CaptainBroach's avatar
      CaptainBroach
      Initiate
        Retired_Member
        Enjoy :smileyhappy:
