adamber's avatar
adamber
RBR20/RBS20--Connecting with Spectrum WiFi6 Router
I recently upgraded to a Spectrum WiFi6 router but am still have connection issues (non-existent or buffering) with a TV on the other side of my house (one story--2000 sq. ft.) as well as a TV that's about 18' away.  I'm told the issue with the closer TV may be due to obstructions in nearby walls.  Regardless, I'm trying to "piggyback" my Orbi RBR20/RBS20 on my Spectrum router to increase coverage and signal strength.  Is this feasible and advisable? Also, how exactly would I do this (i.e., what attaches to what, in what order etc.)?   Note: I glaze over when I read about updating firmware, IP addresses and all that so thanks in advance to whoever can answer this in language I can understand.
  • FURRYe38's avatar
    If your ISP Modem already has a built in router and Wi-Fi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    • adamber's avatar
      adamber
      Hi Furrye38...don't know what the firmware version is and I can't plainly see what the mfr. is on the modem (it's separate from the router).  It's a Spectrum branded unit with a model # of EU2251.  It sounds like from what you say that the piggyback idea is not a good one and I should look for a different solution--either something Spectrum can provide (i.e. a "pod") or using the Orbi system alone (and taking back the Spectrum router), the latter of which was recommended by a Spectrum tech when I called.  The satellite would be placed about 30-35' away from the router if I go that route.  In any case, I'll look at the links you sent.  Thanks.
  • CrimpOn's avatar
    CrimpOn
    Yes.... and Maybe.
    It would help to know what this Orbi RBR20/RBS20 was doing prior to the change in Spectrum equipment.
    * Was it still in the box?
    * Was it connected to the previous Spectrum router?
    From the description, it appears that the situation right now is a Spectrum WiFi router which does not provide a strong enough signal to two TV's.  One about 18' away and the other farther away.
    The Orbi RBR20 can be connected to the Spectrum router using an Ethernet cable.  Just turn it on.  The WiFi credentials are printed on the product label (on the bottom). You now have two WiFi routers located close to each other. Their WiFi radio signals will almost totally overlap.  i.e.
    * No net gain in coverage, and
    * Two radios competing with each other.
    However, the RBS20 can be located 25-35 ft. away from the RBR20. (People advise to start at 30' apart, but the satellite has to have an electrical plug and there usually aren't plugs in the middle of rooms.)  This creates another WiFi radio that will cover more of the house.
    At this point, must people would turn off the Spectrum WiFi signal.  It wll just confuse things going forward.
    Also at this point, you get to decide if you want to change the WiFi 'name' and password of the Orbi system.
    * One choice is to give it exactly the same credentials as the Spectrum router.  If you decide
       to remove the Orbi and use the Spectrum again, every device will automatically reconnect.
    * Every time I replace my WiFi router, I give the new one exactly the same WiFi name and password as the
       one being replaced.
    It's up to you.
    Also at this point,
