sailon1's avatar
sailon1
Follower
Nov 09, 2020
RBR20/RBS20 Wifi interrupts?
Our church has an RBR20 router and 3 RBRS Satellites. We placed an RBR20 Satellite in our church balcony to be able to connect a new computer that runs our new live streaming system. We are getting speedtest.net upload scores of 16 Mbps.
Our problem is the last two services, we've had one instance (each service) where the video and audio freezes for a second or two, then extreme fast forwards to catch up and then resumes the stream at the expected pace. This happens both on recordings (with OBS), as well as live streaming using OBS to YouTube.
Is the Orbi 20 Series up to the task of solid streaming upload, or do we need a hard wired (very difficult) connection from our streaming computer to the base router?
Appreciate any advice! Thanks!
1 Reply
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
