ctu5000
Oct 29, 2018Aspirant
RBR40 - Configuring as Access Point
I have searched/read existing discussions/knowledgebase articles, (and talked to customer support without much help) but haven't found a clear answer to my question...
I have an existing wifi netwo...
Oct 29, 2018Guru - Experienced User
You sould need to make sure the 2.4Ghz and 5Ghz radios are far from each other for each router unit. Your main host would be set to 1 and the Orbi to 11 on 5Ghz.
I would be best to disable the main routers wifi and just run the Orbi wifi alone...
Is this in a home or apt?
- ctu5000Oct 30, 2018Aspirant
Thanks... I'll take a look at that.
