Animal827
Apr 13, 2026Aspirant
RBR40 Blinking White Light
At about 3pm today I started experiencing connection issues on some devices, so AI decided to reboot the RBR40. It will not reconnect to my Verizon modem . It remains in a pulsating white light. ...
- Apr 14, 2026
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Can try option #2 first...
Apr 14, 2026Guru - Experienced User
What verizon modem is it?
Animal827
Apr 14, 2026Aspirant
So apparently, after 3 or so hours I started to get some connectivity back. I tried to update to latest firmware during this time, but the Orbi app AND website said I had the latest Firmware. Strange. My RBR40 and my RBS20s remain in the same firmware version. The Verizon modem is the G1100. As of right now, there are no issues.
I did check the Verizon router directly and I had Internet access.
I have had the same setup for 7+ years, I found out that I had a double NAT situation going on, so I changed the Orbi to AP mode and basically lost all setting options.
I am not sure what happened here or if it is a song of things to come. Any thoughts here...
- FURRYe38Apr 14, 2026Guru - Experienced User
Couple of options,
- Animal827Apr 14, 2026Aspirant
Yes. I found out about my double NAT. I removed all wifi options on my Verizon FIOS G1100 Modem/Router and set my Orbi RBR40 into AP mode.
Is there a better option (e.g., performance or function benefit) from way or another. For example, would it be better to set Verizon modem to bridge mode and have Orbi manage my network?
I have been seeing different views on this (e.g., not being able to properly or fully set modems to bridge mode). Setting Orbi to AP mode really takes away a lot of the functions of Orbi (which may be available on the Verizon modem itself).
- StephenBApr 14, 2026Guru - Experienced User
If you have their set top boxes, then you'll need to keep their router in router mode.
I use FIOS as well, and have chosen to double-route. IMO the disadvantages are overstated. You just need to be careful about port forwarding.
