DickDuke's avatar
DickDuke
Apprentice
Nov 18, 2018
RBR40 Firmware Trials, Tribulations, and Partial Solutions
Summary RBR40 = Firmware issues and bugginess RBR20 = small, simple, solid reliability RBW30 = Simple addon satellite Orbi Overall = Powerful and highly customizable. Perfect for network geek...
  • DickDuke's avatar
    DickDuke
    Nov 19, 2018
    Thanks for suggestion, but yes, I tried those things and more.
    Keep in mind that the same issue would apply to the working solution, ie/ the RBW30 synching to the RBR20 (works fine) is the same as getting the two RBS20 satellites synching with RBR40. For whatever reason, I was able to (eventually) get any combination of two satellites to synch with the 40, but only the 20 successfully connected to all 3 satellites.
    i may try again after the next firmware update for the RBR40, but since my setup is now working and stable, I’ll leave it “as is” for now.
