thesleepdoc's avatar
thesleepdoc
RBR40 firmware update to 2.7.5.6 legit?
Greetings all! Long time lurker, first time poster.
I still run my old Orbi AC2200 Tri-band WiFi Router (RBR40) as a guest network, and noted that, even though it has been end of service for a while, I just received notification through the Orbi app of an update to firmware version 2.7.5.6. I haven't installed it yet, because I don't see it referenced on the Netgear webpage for the router (#Orbi RBR40 | WiFi System | NETGEAR Support).
Is this a legit update that I should install?
Thanks in advance for your help!
  • FURRYe38's avatar
    If it's being seen in the RBRs UI or Orbi app then yes it's valid and legit. Was mentioned in another post that it's legit. NG seems to take there time on getting files posted and can push via Auto Update first which has happened in the past. Then they will post the FW files later on. Up to you if you update. Be sure to allow the RBS to be updated as well if you do. Those should update first. I recommend bringing any RBS closer or to same room as RBR to ensure they get updated properly.
    Or hold off until files show up.
    • thesleepdoc's avatar
      thesleepdoc
      Thanks! I'll probably await the official post (though I wonder if it will come since the product is technically End of Service).
      • FURRYe38's avatar
        Though EoL, some security issue may be pushed as a priority. Just have to keep an eye on the download site. Hopefully they will get them posted soon.
        KevinLiT
