DOD-March's avatar
Apr 06, 2020
RBR40 losing internet connectivity every 12 hours or so
Hi,
My Orbi RBR40 (model name doens't list in the pull down) wifi router with 2 sattelites is losing internet connecivity every ~12 hours or so. Wifi connection to the Orbi is maintained and I can reach the admin services on the wifi router but can't get beyond that to my cable modem.
The cable modem is an Arris supplied by Spectrum / ATT.
-- Dermot
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
    • DOD-March's avatar
      DOD-March
      Tutor
      >> What Firmware version is currently loaded?
       2.3.5.34 (upgraded manually from 2.3.5.32)
      Arris TG1672G
      2.4GHz : Channel 11
      5GHz : Channel 48
      Not many. This is a replacement for a cheapo router I had before. Little did I know the cheapo was rock solid!
      One more thing, there's no seeming issues on the wifi side of the router. It's the connection being dropped from router to modem. I can access the 192.168.1.1 on the router from all devices but can't get to the modem 192.16.0.x during an outage.
      thanks, D
