tensor4u's avatar
tensor4u
Follower
Jan 31, 2021
RBR40 Main Router not broadcasting 5Ghz Network
Hi, My main RBR40 Router is not broadcasting 5Ghz Network at all. I have checked with Wi-FI Analyzer app and Router is not broadbasting 5 Ghz Network at all while Satelitte is broadcasting the network.
Details generally asked:
FW Version: V2.6.1.36
Connected to Nokia G2425G-A Gpon ONT through Lan Cable
Nokia Router in Bridge Mode
Have done Factory reset and restarted, does not help.
Size of the home: 2500 Sq Feet. Distance of Sateliite from Orbi: 25 Feet
What channels are you using? : Auto
Any Wifi Neighbors near by? If so, how many?: Yes, 2 (5 Ghz), 5 (2.4 Ghz)
Settings Enabled:
Beamforicing, MIMO, WMM, Short Premable
Settings Disabled:
Daisy Chain, Armour, Circle, 20/40 Ghz Co-existence,
Can somebody please suggest how can I enable 5 Ghz on Main router again, it is a big pain otherwise.
  • CrimpOn's avatar
    CrimpOn
    Can you please identify which Wi-Fi Analyzer app this is? (There are many apps with the same name)
    On these original Orbi's, there is no user setting to enable/disable the 5G radio.  It is supposed to be on always.  (There is a setting to to enable/disable broadcasting the SSID, but that applies to the router and all sattelites.
    • Kenchoroni's avatar
      Kenchoroni
      I have a similar setup and issue but my RBR50 is on V2.7.2.104.
      A satellite 35 feet away on another floor is on 5G at 200 Mbps.  When I turn off the satellite the main router cranks out <80 Mbps from two feet away.
      This is definitely a router not doing its 5G job.  How can I turn on the router's 5G antenna?
      I used to love my Orbi.
      • FURRYe38's avatar
        What devices are you using to speed test with?
        Check the connection rate between the wifi device and RBR with wifisweet spots app on the device.
        What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
        https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
