Shengfang's avatar
Shengfang
RBR40 no reaction after restarting
After powering off and on the RBR40 there is no light on the top just flashing power yellow on the bottom and there is no signal as well. I need to go through the entire process to set up the mesh wifi. Why is that the case ?
    Reboot all
    why power off in the first place?
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system?
    • Shengfang's avatar
      Shengfang
      ISP side is Nokia G-240G-E but I doubt this is causing the issue; my previous connections at a different home had failed after a year plus.
      • FURRYe38's avatar
        What checking to see if your modem or ONT had any built in router and wifi which yours doesn't.
        Connections at previous place was with same Orbi system?
