tpm's avatar
tpm
Tutor
Dec 30, 2021
RBR40 Replacement
I have a Orbi Router (RBR40) and 3 satellites (RBS20).   My router is broken. I want to replace the router with a newer version, but don't want to replace the satellites.  What Orbi routers are compatible with the RBS20 Satellites
1 Reply
  • CrimpOn's avatar
    CrimpOn
    All of the original Orbi routers are compatible:
    RBR50
    RBR40
    RBR20
    No other models are compatible (Pro, AX, Pro mini, "10" series, etc. etc.)
