bah123
May 11, 2018Aspirant
RBR40 Router dropping Arris TM822A, I think
I bought an Orbi RBK33 system with RBR40 router last November. Intially, everything was fine, but somewhere along the way it appears the router decides to drop it's connection to the modem (perhaps s...
May 11, 2018Guru - Experienced User
Tray swapping out the LAN cable between the modem and router.
Disable IPv6 on the Orbi router.
When you loose connection, can you still access the routers web page?
Do both wired and wireless devices access the routers web page when this happens?
Might have your ISP check your service signal from there side to the modem. Have them check there logs for any disconnections during these times frames. You might check into a newer model modem. Preferably a stand alone modem. No built in router.
Any wifi neighbors near by? If so, how many?
bah123
May 12, 2018Aspirant
Hi,
Thanks for helping!
I think the most important clue may be that we cannot login to our router when we lose WiFi. It doesn't show up as an availble network from any of our devices.
I swapped out the cable with new some time ago.
It's been disabled all along.
No. The router disappears from an available WiFi device so I can't even get onto it.
Presently I only have wireless devices on the network.
>Might have your ISP check your service signal from there side to the modem. Have them check there logs for any disconnections during >these times frames. You might check into a newer model modem. Preferably a stand alone modem. No built in router.
The symptoms of our current problems don't quite fit with dropping the ISP. We fought a long ISP battle over the course of a number of years with our modem dropping the ISP. We could always login to our router but we did not have an internet connection and the LEDs on the modem showed that a connection was dropped. We are experiencing neither of these circumstances presently. In the end, after numerous visits from our ISP's techs, we ended up with a new modem, they boosted our signal level from down the street and finally they figured out the builders did a really **bleep**ty job terminating coax cables.
I don't have a problem replacing the modem and maybe it's worth a shot in the dark? However, it doesn't seem like replacing the modem quite fits the problems we are experiencing (coming from a guy with limited knowledge).
We have around 10 WiFi neighbors.
- FURRYe38May 12, 2018Guru - Experienced User
Try changing to manual channels, 1 6 or 11 that your neighbors are not using. Any unused channel on 5Ghz.
As last resort, try a factory reset:
- bah123May 16, 2018Aspirant
5/12/18
2.4GHz from Auto to Ch1
5GHz from Ch48 to Ch36
Seemed mostly ok. A handful of instances where router needed reset until afternoon of 5/16.
5/16
Router went down and wouldn't even come back up as an available network. It was up/down and then completely down (network name didn't show up in WiFi network list).
>https://community.netgear.com/t5/Orbi/I-found-a-Connection-issue-Resolution-for-wired-backhaul/m-p/1...
I did try a factory reset a few times within the last few months. The first seemed to help for a 1-3weeks. The second reset had no apparent affect. The third seemed to help for 1-3weeks although it still dropped out just less frequently. I did the factory reset again toda (5/16) and the network is up and down.I'm really at a loss.
The link you provided referenced wired backhaul issues. I don't know what this is.
