Littlejonboy
Dec 03, 2018Tutor
RBR40 setup issues
I have rbr40 with supplied RSB40. I wanted a 2nd RBS40 satalite to extend system and replace existing old equipment. New satellite arrived and was still running version 1 of software. Online update...
- Dec 04, 2018
Finally it’s all solved and upto date. The process I ended up taking was as follows
I updated the router first to 1.11.0.20 following the advice from FURRYe38
once the router came back online i was promted to update from the system itself via the app. This done the router to the latsest version and still skipped the satalaite so i thought i was back to were i started two days earlier.
i then had to manually update the new satalite to version V2.0.0.56 on the advice of DickDuke.
Manual update to 2.1.2.18 then onto the latest via onine update as manual would still return errors.
i would like to thank all those who replied to my plight as even the netgear tech support could not resolve my issue!
Dec 03, 2018Guru - Experienced User
If you downgraded the router to match the satellite, then upgrade the statellite, you may need to download a intermediate or middle of the road FW version and apply that to the satellite before applying the most current version. Once you get the satellite fully upgraded, do the same thing with the router, use an intermediate FW version then apply the most current version.
