Littlejonboy
Dec 03, 2018Tutor
RBR40 setup issues
I have rbr40 with supplied RSB40. I wanted a 2nd RBS40 satalite to extend system and replace existing old equipment. New satellite arrived and was still running version 1 of software. Online update...
- Dec 04, 2018
Finally it’s all solved and upto date. The process I ended up taking was as follows
I updated the router first to 1.11.0.20 following the advice from FURRYe38
once the router came back online i was promted to update from the system itself via the app. This done the router to the latsest version and still skipped the satalaite so i thought i was back to were i started two days earlier.
i then had to manually update the new satalite to version V2.0.0.56 on the advice of DickDuke.
Manual update to 2.1.2.18 then onto the latest via onine update as manual would still return errors.
i would like to thank all those who replied to my plight as even the netgear tech support could not resolve my issue!
DickDuke
Dec 03, 2018Apprentice
I had some initial setup grief with my RBR40 too.
An intermediate firmware allowed me to move forward.
Not sure if it will help you too, but maybe the V2.0.0.56 firmware will be the magic version for you. Perhaps if you can get all of your Orbi devices to there, you’ll be able to get everything connected?
Eventually, I did get everything working with latest firmware.
.... at least so far!
Resources:
RBR40 latest firmware rBR40 V2.2.1.210
http://www.downloads.netgear.com/files/GDC/RBK40/RBR40-V2.2.1.210.zip
RBR40 intermediate firmware rbr40 v2.0.0.56 (required to apply the previous update)
http://www.downloads.netgear.com/files/GDC/RBK40/RBR40-V2.0.0.56.zip
Littlejonboy
Dec 04, 2018Tutor
- FURRYe38Dec 04, 2018Guru - Experienced User
Glad you got it working. You should be good now. Do a save configuration to file after you have set up everything on the router.
Enjoy. :smileywink:
