janfossi
Oct 30, 2020Aspirant
RBR40 Slow WAN Connection
My RBR40 is giving no more than 150Mbps on the WAN Port.
I have a 400Mbps download and 200Mbps internet connection which I tested connecting my computer directly to the ethernet cable with similar speeds.
When I connect the RBR40 even though it correctly negotiates a GigabitEthernet connection (Full Duplex 1000Mbps), it can't reach more than 150Mbps of download and 100Mbps for upload speed.
I tested with the SpeedTest app included on the router, so I'm testing the WAN Ethernet speed and not the WIFI. I also connected my computer to the LAN Ethernet port, reaching similar speeds. Wifi is aprox. 150 as well.
Please your suggestions!
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- FURRYe38Guru - Experienced User
Check the speed with a wired PC at the ONT with out the RBR connected.
Be sure your using a good quality LAN cable between the ONT and RBR. CAT6 is recommended.
Power OFF both ONT and RBR for 30 seconds then back on.
