cmaustin's avatar
cmaustin
RBR40 slow wifi
Hello, I have the RBR40 and the two wall plug satellites that came with it. System has work great for over a year. In the past few weeks, the wifi speeed slowed to a crawl. I was about 300mbps down, now I get 1.5mbps on my iphone! My laptop does ok but other laptops are slow too. I have the lastest firmware, etc. When I run speed check in the app, it say I'm getting 450mbps down from my cable modem to the Orbi router. Not sure what to do??!! Any ideas? I didnt change anything.
  • FURRYe38's avatar
    Has the system been powered OFF for 1 minute then back on?
    • cmaustin's avatar
      cmaustin
      Orbi Firmware: Router V2.5.1.16 Satellite: V2.5.0.4
      Spectrum Internet Box: Hitron E31N2V1
      1 min off reboot: Yes
      Channel: Auto
      3850 sq ft home. Sats are about 30 feet from the router.
      I have not tried differnt channels. Is that my only hope to fix?
