MMSOOD's avatar
MMSOOD
Follower
Dec 08, 2019
RBR40 stopped working with Wi-Fi calling
I have Google Fi phone service and use wi-fi calling when at home. In fact, I use wifi for everything on that phone while at home.
Text works ok
Data works ok
Incoming call work ok
Outgoing calls cannot be completed with using my home (orbi) network
If I take my phone (pixel 3a xl) to the local coffee shop and use their wi-fi, then outgoing calls work also.
I have done some troublehsooting using information on here but nothing has worked so far
  • I have turned off daisy-chain tol;ogy
  • I have disabled SIP ALG
Any help would be appreciated
  • FURRYe38's avatar
    Try enabling Beamforming, SIP ALG, and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    Armor, Circle, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi MMSOOD
    If you have Disney Circle enabled, kindly disable it, test WiFi calling and let us know the result.
    Blanca
    Community Team
  • Blanca_O's avatar
    Blanca_O
    Hi MMSOOD
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
    Blanca
    Community Team
