bgladden43
Nov 16, 2020Aspirant
RBR40 to ATT Fiber using Arris BGW210
I have read several threads on setting this up. First, do not trust your ATT installer. They said to just plug in the Orbi like I did with Xfimity and it will work fine, not true. What is the best set...
Nov 16, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
https://community.netgear.com/t5/Orbi/Configuring-ORBI-RBR50-with-ATT-Fiber/m-p/1999922#M106198
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756
bgladden43
Thanks Furrye38.
Curious on why 3 options versus one. I’ve read the IP Passthrough Lolita the number of devices. I’m not technical so easiest one to setup that will work in a home/multiple devices setup. Thanks
- FURRYe38Nov 16, 2020Guru - Experienced User
Option #3 will be the easiest....
