KLZ
Jun 01, 2025Follower
RBR40 to Starlink Gen 3
I'm not tech savvy, but I know enough to get by, maybe enough to be dangerous. I have the RBR40 and I just hooked up the Starlink Gen 3. The Starlink works great but it looks like the signal is not a...
Jun 01, 2025Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
