Cjo007
Jan 05, 2026Aspirant
RBR40 Unable to reset.
Hi i have a RBR40 that is unable to reset. No matter how much and how long I Press the reset button - nothing happens. Has anyone managed to fix this known problem? And please don’t tell me to ta...
Cjo007
From previous posts in this forum I got the understanding that this was a known error in firmware.
So I was hoping, that someone found way around this, that doesn't involve destroying the orbi.
Jan 05, 2026Guru - Experienced User
Cjo007 wrote:From previous posts in this forum I got the understanding that this was a known error in firmware.
It's been some years since I used the RBR40, but I don't think it is firmware. Are any of the LEDs lit?
If you haven't tried using one of the satellite power adapters with the RBR, then I'd start by doing that. If that doesn't change the behavior, then you could try opening the case (or replace it).
