Sassytam's avatar
Sassytam
RBR40 will not allow streaming Xfinity
I recently purchased the RBS40 will not allow me to stream Xfinity from my Roku Stick.  It will also not allow me to access ESPN app on my IPhone and other websites from my Iphone.  I would like to cancel the Bitdefender subscription and see if that helps, but right now the entire system is collecting dust because it won't work with Xfinity or apps on my Iphone.  Any ideas what to do next?
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • Sassytam's avatar
      Sassytam
      So I have a NETGEAR Modem - CM1105v Nighthawk cable voice modem. No built in router, just modem. Firmware 2.3 .5.30 for the Orbi.
      • FURRYe38's avatar
        Ok, thank you for letting us know about the modem.
        What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
        Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
