asuirish
May 15, 2025Initiate
RBR40 with 3 Satellite
I've had this system for about 5 years now but have consistent signal issues for the past 6 months. Satellites in the same locations. We have an older brick home and a finished basement. I have done ...
- May 21, 2025
Appreciate the response. I just bit the bullet and upgraded to the 870 and my issues have been resolved it seems.
May 20, 2025Guru - Experienced User
A sketchy satellite can make for a sketchy system. If you've had this more than 5 years, might be time to do a little testing. You could try turning off a satellite each day to see if the system stays stable and if it works better/worse (other than slightly less coverage with missing one).
You could also test each satellite with a hardwired device to the satellite to see if its still performing to spec with the backhaul. If one of them is having backhaul issues, it could cause issues for the device connected to it
asuirish
May 21, 2025Initiate
- plemansMay 21, 2025Guru - Experienced User
That's one way to do it!
- FURRYe38May 21, 2025Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
