asuirish
May 15, 2025Initiate
RBR40 with 3 Satellite
I've had this system for about 5 years now but have consistent signal issues for the past 6 months. Satellites in the same locations. We have an older brick home and a finished basement. I have done ...
- May 21, 2025
Appreciate the response. I just bit the bullet and upgraded to the 870 and my issues have been resolved it seems.
asuirish
May 21, 2025Initiate
May 21, 2025Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
asuirish wrote:Appreciate the response. I just bit the bullet and upgraded to the 870 and my issues have been resolved it seems.
