luigibr's avatar
luigibr
RBR40 x FVS318G x URL Filtering
Good evening, I would like to add firewall and url filtering to my network (for example: I want to block some youtube channels (https://www.youtube.com/channel/{channelID}). While researching the Internet I found that it seems I could achieve this with FVS318G.
Is there anyone here that uses this kind of setup? And how it is implemented?
Do I still need for example a Internet Security Suite installed on my machines?
Will this make my network slower?
    • luigibr's avatar
      luigibr
      Thank you for the reply CrimpOn . Do you know if OpenDNS can handle blocking partial URLs? Because I don't want to block for example youtube at all just some channels. And I have Pi-Hole installed, but it only handles the domain not partial URL. I am still planning to install Squid proxy, just need more time to understand how it works.
      • CrimpOn's avatar
        CrimpOn
        Several posts have talked about using OpenDNS, but I have not.  It's the "Wild West" at my house.
