GSzab's avatar
GSzab
RBR40
Just did the lates firmware update and one of my satellites did not update and will not connect any advice.
  • have you tried hardwiring the satellite into the router?
    Then trying the update/sync?
  • FURRYe38's avatar
    What version had been loaded?
    How did you update the RBS? RBS should be updated first, then update the RBR lastly.
    • GSzab's avatar
      GSzab
      Currently running V27.4.24 on the base and one satellite while the other satellite is still on the old version v7.3.22 and will not update  I tried rebooting and did not work the one rbs20 will not connect .  I logged on to the app this morning had a message to update firmware and clicked update.
      • plemans's avatar
