menozzi2
Sep 03, 2025Aspirant
RBR40
I know the RBR40 has been retired.
Is it capable of 1GB speeds?
Wired yes.
Wireless expect around 200-300mbps in real world usage.
For most, thats fine because streaming 4k only takes 25-50mbps.
So unless you're moving massive data quickly, it still does a pretty solid job.
IF the WAN and LAN side ethernet connections are good, you could see around 900Mpbs over ethernet only. WiFi will not see this speed.
Wired yes.
