tgarvey
Oct 11, 2018Tutor
RBR40/RBS20 dropped connections
I have an RBR40 and three RBS 20s. All are on FW 2.2.1.210. Several times a day the satellites loose connection to the RBR40. They are in "Magenta" state much of the time. I have a two-storey, 31...
tgarvey
Oct 19, 2018Tutor
I don’t recall whether the upgrade was a manual or auto. According to the Network Map, daisy chain is not enabled.
this has been a chronic problem. I shouldn’t have to be a nerwork engineer to get this to work. I’m probably going to request an RMA and replace this with something reliable.
Oct 19, 2018Guru - Experienced User
As a last resort, try this:
If not, then you'll need to contact NG support and ask about an RMA.
Good Luck.
