slkotr's avatar
slkotr
RBR44
Bought orbi mesh to help with wifi coverage. Having trouble with Comcast tv boxes pulling tv channels.
Comcast modem set to bridge mode.
Orbi router set to dynamically pull DHCP
Changed ip range to match Comcast modem DHCP.
Rebooted main DVR and the tv boxes.
Still nothing.
Comcast service has no solution
Any suggestions?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You may want to use the comcast modem as a router and set the Orbi in AP mode to get the better wifi coverage.
    DarrenM
    • slkotr's avatar
      slkotr
      Thank you for your help. I tried your suggestion and it worked. I would have preferred to set it up the other way around. But the wife is happy and her tv is working.
