Knorske's avatar
Knorske
RBR50 - Attached not showing
I have had the RBR50 (and satellite) for a couple of years.  All was going well until the last few days.  I "installed" a new computer when some "challenges" appeared.  I have five Netear NAS on my home network.  When I try to access them, only three of the five are available.  Going to OrbiLogIn.com, all five show as being "attached" devices. I have turned ON "access," as well.  No change.
Any suggestion as to what I should do get all five NAS showing as part of my network?
Thank you.
  • FURRYe38's avatar
    Do other PCs see the NAS?
    Refer you to the PC and Windows support for help and information regarding how to connect to Network Shares. You might hit up the NAS forum for help and information as well.
    • Knorske's avatar
      Knorske
      The two "missing" NAS do show on my laptop computers.
      I have tried "reset," "restart" for the RBR50, checked with Dell about computer update, same for Windows 10.  Using Orgilogin, all five NAS show as "allowed" with status as "wired."
      Again, on TWO desktop computers, only three of the five NAS show as part of "Network."  All five show on the laptop computers under "Network."  Of course, those NAS NOT showing on "Network" can not be accessed (by the two desktop computers).
      Is there some sort of "status" or other option which will result in the two desktop computers having access to the "missing" NAS.
      I did just "install" one of the two desktop computers, loaded Windows 10 (and have downloaded all updates), but the effect of NOT seeing the two "missing" NAS is a problem for BOTH desktop computers.  For the existing desktop, I made no changes, no new software, etc., when or after installing the "new" desktop computer.
      This is very frustrating!  EVERYTHING seems to be "operating properly," but the two NAS will not appear!!!
      Anyone else have some suggestions as to "next steps"?
      Thank you.
      • CrimpOn's avatar
        CrimpOn
        There was a similar issue with a NAS last week, and the problem was solved by powering off the entire Orbi network and restarting.
        (Not "Factory Reset", just power on again.)
    • CrimpOn's avatar
      CrimpOn
      I agree with FURRYe38 . Orbi recognizes the NAS boxes and shows them connected to the network.  This has something to do with the computer-NAS process. Netgear has a bunch of forums for NAS   at https://community.netgear.com/t5/NETGEAR-Forum/ct-p/en-netgear
      (scroll down...and down...and down...)
      Are the laptop computers running the same Windows software and applications as the desktops?
      Is there enough space on one of the newer NAS that the new computer can see to hold the contentsof that oldest NAS?
      Might consider using a laptop that has access to both to duplicate those essential files.
      • Knorske's avatar
        Knorske
        Thank you CrimpOn ...
        I would like to transfer the data, unfortunately, the one I REALLY need is the one even the laptops can no longer "see."
        I will try some of the other links you provided.
        Thank you, again.
