chucktalk
Jul 06, 2018Follower
RBR50 - can the USB port be used for Ethernet?
I have used all three ports on the Router, two PCs and one VOIP. I want to know if I can use the USB for Ethernet to add a Firewalla or CUJO or other device. Does anyone know if that can work?
1 Reply
- st_shawMaster
No, you cannot. If you need more ports, you can hang a switch off one of the Orbi LAN ports.
