Steve001
Apr 06, 2018Guide
RBR50 - Connecting a device to 2.4GHz only
How can I make sure that a device I'm pairing with my Orbi Router (RBR50) is only connecting to the 2.4 GHz Network (not the 5)?
(This device needs to be paired with the 2.4 GHz wifi.)
Thanks,
Steve
- Anonymous
I can tell you how I did this. Not sure if it'll work today due to changes in the FW.
My Lacrosse weather would only connect on 2.4g phone app.
Had to turn the 5g signal down as far it would go and unplug one of the sats. This allowed the phone to connect 2.4g
Once the weather station was connected I put all settings back.
- Steve001Guide
I tried something like that, trying to set up next to my 2.4 GHz satellite. It didn't help. I could try unplugging the 5 GHz satellite, but don't think I can turn the 5GHz signal down. I did try turning it off. Again, that didn't work.
Thanks for the ideas.
- st_shawMaster
Thanks,
Steve
See this thread. Read it all the way through, as some people have had issues with later firmware versions and an alternate procedure was posted. I'm not sure how/if this works with the latest firmware.
- Steve001Guide
Thanks, I'll read that link.
So what you're saying is that the Orbi should automatically link to 2.4 GHz, if the device can only see 2.4 GHz? In other words, the Orbi won't continually try to push the 5 GHz connection to that device?
- FURRYe38Guru - Experienced UserCorrect. If client devices don’t support 5ghz, the device would not connect to that radio.
ORbi systems are based on automatic detection and connection to frequencies based on device support. Orbi systems us Smart Connect to get devices connected to the best mode and frequency based on signals and device support. It's all automatic.
