toofast
Sep 28, 2020Tutor
RBR50 - CPU 100% then reboot after reboot
Ok, finally hopefully making progress....been doing a ton of reading. It looks like there are issues out there, but can't find a difinitive fix. I uploaded screen shoots of my CPU. I have ab...
toofast
Dec 20, 2020Tutor
Yeah I am going to have to...only ran a week then started randominly rebooting.
| CPU Load | 98.3299% |
toofast
Dec 20, 2020Tutor
Is this the version I should try ?
All I could find.
RBR50 / RBS50 Firmware Version 2.6.1.40
- FURRYe38Dec 20, 2020Guru - Experienced User
- FURRYe38Dec 21, 2020Guru - Experienced User
Let us know once you get v16 manually downloaded and manually installed.
toofast wrote:Is this the version I should try ?
All I could find.
- toofastDec 21, 2020Tutor
Once I update that firmware to v16, do I need to also do a Factory reset, which was bloody painful last time.
- vajimDec 21, 2020Master
toofast wrote:Once I update that firmware to v16, do I need to also do a Factory reset, which was bloody painful last time.
try this:
To back up the router configuration settings:- Launch a web browser from a computer that is connected to your Orbi's network.
- Enter orbilogin.net. ...
- The BASIC home screen displays. ...
- Click ADVANCED > Administration > Backup Settings.
- Click the Back Up button. ...
- Specify a location on your computer to save the file.
to restore:
To restore your backed up configuration settings:
- Enterorbilogin.net.A login screen displays.
- Enter the router user name and password.The BASIC home screen displays.The user name is admin. The password is the one that you created during the initial setup of your Orbi. The user name and password are case-sensitive.
- Click the Browse button, then locate and select the backup file that ends in .cfg.
- Click the Restore button.A warning screen displays.
- Click the OK button.Your Orbi settings are restored and your Orbi router restarts.Warning: After you click the OK button, do not try to go online, turn off the extender, shut down the computer, or do anything else to your Orbi router until it finishes restarting.
