th3sp3ck
Aug 09, 2020Guide
RBR50 - Ethernet works but Wifi Doesn't - Help?!!
All of the sudden my wifi stopped working. I've rebooted modem and router a few times. Help would be greatly appreciated!
When I open Chrome and go to a website, I get the following error in Chrome on my Laptop is:
Your connection is not private
NET::ERR_CERT_AUTHORITY_INVALID
Subject: www.routerlogin.net
Issuer: www.routerlogin.net
Expires on: Nov 26, 2029
Current date: Aug 9, 2020
PEM encoded chain:-----BEGIN CERTIFICATE-----
MIIEETCCAvmgAwIBAgIJAN9ro99KqYZ3MA0GCSqGSIb3DQEBCwUAMGUxCzAJBgNV.............
-----END CERTIFICATE-----
Hardware Version: RBR50
Firmware Version V2.3.5.30
your firmware's a bit out of date.
i'd start by updating that first.
What modem/gateway is it connected to.
- th3sp3ckGuide
I updated the firmware - v2.5.1.16 and I have fiber with a CTC GSW-1005MS switch that connects directly to my Orbi.
I did do one other thing that seems to be helping but created a new issue. I unplugged my satellite and now my wi-fi is working but the family cant get a stable connection upstairs.
I moved the satelitte downstairs and I've been trying to reset/reconnect the satelitte but no luck. I used a paper clip to reset it and then followed the instructions on the App but the satellite just pulses white and never connects. Thoughts??
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerOne User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
