Brent_Orbi
May 11, 2020Tutor
RBR50 - No Ethernet Cable Is Plugged into the Orbi Router Internet Port
Device is about 18 months old. We lost power last night, and the system did not come back up. After a ton of troubleshooting: 1) Router was not getting IP from cable modem 2) Laptop to cable m...
May 11, 2020Guru - Experienced User
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Power OFF the ISP modem and RBR for 1 minute. Then power ON the modem and let it sync. Power ON the RBR and check the status. If still nothing, try same process with modem and do a factory reset on the RBR and walk thru the setup wizard with a wired PC.
- Brent_OrbiMay 12, 2020Tutor
Hey, its a Surfboard SB6183. I own it. I've rebooted in every order imaginable. I left the modem off for 30 minutes..
Still says there is no cable plugged in.
Thanks.
- FURRYe38May 12, 2020Guru - Experienced User
So a direct connected wired PC or laptop with the modem works right?
Even after a factory reset, if the status still says no cable and the RBR is not working, Possible bad RBR unit.
You can try updating the RBRs FW and see:
Disconnect the RBR from the modem while you do this.
Update the RBS first then RBR. After the RBR comes back to ready, factory reset the RBR, reconnect the RBR to the modem and walk thru the setup wizard...if this still fails, the RBR needs to be replaced. Return it to place of purchace or make contact with NG support and ask about an RMA.
I was affraid of that. I finally got my old router out and it's working.. I've tried plugging the RBR into that LAN port to at least get an IP and see if it will flow but that has not worked as well. Firmware is updated to the latest version..
I'll try to get Netgear to RMA it. We'll see.. It's 18 months old so I am expecting a big fat nope.
