Brent_Orbi
May 11, 2020Tutor
RBR50 - No Ethernet Cable Is Plugged into the Orbi Router Internet Port
Device is about 18 months old. We lost power last night, and the system did not come back up. After a ton of troubleshooting: 1) Router was not getting IP from cable modem 2) Laptop to cable m...
Brent_Orbi
May 12, 2020Tutor
Hey, its a Surfboard SB6183. I own it. I've rebooted in every order imaginable. I left the modem off for 30 minutes..
Still says there is no cable plugged in.
Thanks.
May 12, 2020Guru - Experienced User
So a direct connected wired PC or laptop with the modem works right?
Even after a factory reset, if the status still says no cable and the RBR is not working, Possible bad RBR unit.
You can try updating the RBRs FW and see:
Disconnect the RBR from the modem while you do this.
Update the RBS first then RBR. After the RBR comes back to ready, factory reset the RBR, reconnect the RBR to the modem and walk thru the setup wizard...if this still fails, the RBR needs to be replaced. Return it to place of purchace or make contact with NG support and ask about an RMA.
- Brent_OrbiMay 12, 2020Tutor
I was affraid of that. I finally got my old router out and it's working.. I've tried plugging the RBR into that LAN port to at least get an IP and see if it will flow but that has not worked as well. Firmware is updated to the latest version..
I'll try to get Netgear to RMA it. We'll see.. It's 18 months old so I am expecting a big fat nope.
- FURRYe38May 12, 2020Guru - Experienced User
Great trouble shooting step to test that. Ya, probably not in warranty. :smileysad:
Brent_Orbi wrote:I was affraid of that. I finally got my old router out and it's working.. I've tried plugging the RBR into that LAN port to at least get an IP and see if it will flow but that has not worked as well. Firmware is updated to the latest version..
So:
1) Confirmed entire ethernet switch is bad. All the ports hardware link but dont pass traffic. (Switched Orbi to AP mode to check. No dice)
2) As expected, Netgear support has told me to go pound sand on RMA (Device is out of warranty by 6 months).
Since you cannot buy the RBR50 by itself, I could go buy a RBR20 (Maybe), get less range, and have to buy a switch because it has less ports, or I could get the cable modem version which I dont need... Or go used on Amazon and hope it works.
Honestly, I'm a little bummed out. The most expensive home router system Netgear sells and it's basically a brick. Guy on phone was appologetic but unhelpful once we confirmed the hardware was bad.
I would try amazon to see if one works there. If it doesn't you can at least send it back. You get 30 days with Amazon.
It's cheap enough to add a switch if you get the RBR20.
