NeedOrbiHelp's avatar
NeedOrbiHelp
RBR50 - RBS50 need outdoor access point
I have an RBR50 connected to 3 RBS50s and an RBS50Y on the way to sit outside and extend the network into the yard.  I need some sort of a wireless access point at the end of a driveway for a camera - wireless to ethernet.  I know I can use the Orbis "as an access point" but is there a netgear product (or other, ?ubiquity?, TP Link?) that plays well with Orbi and can give me a nice connection to ethernet for the single cam? Any recommendations appreciated!
  • Are you sure about the terminology here?
    An access point is usually understood as providing wireless access to other wireless clients with a wired backhaul (ethernet uplink).
    The RBS50/ RBS50Y would more accurately be described as mesh satellite, with the RBS50 also allowing (optionally) a wired backhaul instead of a purely wireless one (given the central configuration over the mesh, I wouldn't quite call this mode of operation AP mode - but it comes close) - the RBS50Y however only offer a wireless backhaul.
    As I understand your problem, you're not really looking for an outdoor AP, but more for an outdoor client-bridge (something the RBS50 with its 4 ethernet ports can do, as in distributing the wireless backhaul to the connected ethernet devices) - while the outdoor capable RBS50Y does not provide the necessary ethernet ports (and watertight ethernet sockets are difficult/ expensive; available as mil-spec).
    Personally I'm not aware of an orbi compatible outdoor mesh satellite with >=1 ethernet ports, nor any outdoor repeaters (which usually come with their own can of worms, as they don't integrate into the orbi backhaul and usually aren't as network transparent as one would like). If you need ethernet, the easiest option would probably be to mount a normal RBS50 in a rugged cabinet (water tight enough, within supported humidity and temperature ranges - I guess in practice the RBS50 would take more abuse than strictly allowed) - or to use wireless cameras.
    • FURRYe38's avatar
      What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
      https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
      Having 3 RBS online, you should have more than enough coverage inside and out side if placed well.
      • pkgadd's avatar
        pkgadd
        Luminary
        FURRYe38, as far as I understand the problem, it's less a question of absolute range (although that might very well be another aspect) - but rather of finding a way to wirelessly connect ethernet-only devices to the network. With indoor devices such as the RBS50, this is easily possible (wireless backhaul, using the RBS50's ethernet ports to connect the wired devcies - all you need is power), but I'm not aware of an outdoor equivalent (the RBS50Y is weather proof, but offers no ethernet port for further wired devices to use).
  • CrimpOn's avatar
    CrimpOn
    Solution #1 would be to run an ethernet cable out to the camera location.  Outdoor rated CAT5e cable is not expensive.
    (Alas, installing ethernet cable is neither quick nor cheap.)
    Solution #2 is what I did: Purchase a WiFi security camera. "Problem solved."
    (Alas, your security system may not support WiFi cameras. Dang.)
    Sollution #3 is a gizmo that connects to the Orbi over WiFi and has an ethernet port for the camera..  A Netgear EX3700 is one such gizmo, as is the TP-Link N300.  The KEY to all this is that there is electrical power at the camera location (a) to power the camera and (b) to power the "WiFi to ethernet" gizmo that connects the camera.  My guess is the camera is already weatherproof, so the problem is making the gizmo and its electrical supply weatherproof.  Put it into a plastic enclosure and somehow weatherproof the electrical cord.
  • I may take into account seriously what you had said if Netgear might remark that Powerline Utility D 3.1.0.Four does now not guide positive old PLAs but they did not in any of their files supporting this application.
