Achilles716's avatar
Achilles716
Follower
Jan 12, 2021
RBR50 - Transfer ownership to someone else
I have an RBR50 Orbi router with an RBS50 satellite.  I would like to give these to a friend of mine, but I don't want them on my Netgear account anymore.  They aren't under support anymore (expired in April of 2020), so i can't open a ticket without buying a support contract.  Is there a way to transfer these (or at least remove them from my account)?
I wish I had known this before purchasing.  It seriously limits the value of the solution if I can't resell it (eBay, for instance) or give it to someone else (family, friends).
Thanks!
1 Reply
  • FURRYe38's avatar
    Contact a Forum moderator to help you out.
    You can log into your NG account profile and check status there and see if you can remove the system of your profile. https://www.netgear.com/support/#
    A forum moderator will be able to help you more.
