LAGuy
Apr 15, 2019Tutor
RBR50 - WiFI Calling Rarely Works
I realize that this question has been posed by others, but there is not often a good resolution to this in other posts. We have an iPhone 6 and 8 here at home, which is a 3-story townhouse, and the t...
- Apr 16, 2019You’re not going to want to hear this, but I’d probably start from scratch with a full factory reset .
Don’t break band steering. Disable daisychain if you don’t need it. I’ve disabled 20/40 coexistence here. Enable all 3 of the advanced wireless features.
See if just doing this much fixes your WiFi calling. It did for me.
When doing the full reset, I’d turn off ALL wireless devices and leave all wired devices disconnected. Use the paper clip method to reset the Orbi. Router first and then satellite.
As for which 5GHz channel to pick, the best way to know is by using a tool that can do a site survey. Android benefits by having a wonderful app called WiFi analyzer.
Apr 16, 2019Guru - Experienced User
What the FW updated via Auto update or manually loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Ensure that beamforming and mimo and WMM are enabled. You can disable Daisy Chain.
Leave all other settings at default, this would include SIP ALG after you do the factory reset....
LAGuy
Apr 16, 2019Tutor
Do appreciate your guidance, and will do the factory reset shortly (once I have time set aside in case something happens with this).
I do the automatic updates on for the Orbi router and the two satellites. The townhouse is about 2050 sqf, over 3 floors. The router is about 35 - 40 feet away from the satellite on the 2nd floor (with some walls in between), and about the same from the satellite on the 1st floor (with two floors and a wall in between). I had actually set the power on the 5Ghz to 75% (per another post on WiFi issues last year) and it seemed to help in devices connecting properly. The 2.4 is set to full power, with no issues there. Have had problems trying to find an IOS app with tells me the channels in use in my area, but, will reload a Windows desktop app to a laptop that I had used before (the name escapes me) to check which ones are not overloaded.
I use my own cable modem (about a year old), which is a Linksys CM3024.
Will let everyone know the results of the factory reset shortly, have already made the other changes (no affect obviously).
- gr8shoApr 16, 2019VirtuosoIt might be easier to just buy an amazon fire HD tablet on sale and install google play store on it to download the WiFi analyzer app.
- LAGuyApr 17, 2019Tutor
I did find a way to scan for channels on an iPhone using an Apple app, and it works. For my situation, most of the traffic is on 2.4Ghz, but do have two other 5Ghz-based networks around me.
https://www.accessagility.com/blog/free-wifi-scanner-for-iphone-and-ipad-without-jailbreak
- SW_Apr 17, 2019Prodigy
MrMediaGuy had a good suggestion for a tool he used to identy his WiFi issue with the Orbi. It might help identify WiFi jitter issue with your Orbi setup, which could cause the drops. You can give a try with your phone and see if you are seeing a lot of RED xx's.
http://www.dslreports.com/tools/puma6
Check out his experience here:
- FURRYe38Apr 17, 2019Guru - Experienced User
Let us know how it goes after a reset. Be sure Beamforming is enabled and Daisy Chain is disabled after the reset. You can try enabling or disabling Fast Roaming to see if this doesn't anything different.
FYI, your ISP modem is a modem only and thats good, however it's Intel chipset based and Puma 6. There are known problems with modems with Intel chip sets built in:
