Kennyhk's avatar
Kennyhk
Follower
Jul 19, 2020
RBR50 + RBS40
Is possible to configure  RBS50 and RBS40 work together?
such as RBR50 + RBS50+RBS40
OR RBR50 +RBS50 then set RBR40 and RBS as AP
1 Reply
  • FURRYe38's avatar
    Yes on the first one.
    You can configure the RBR40 as a wired AP only if you want to use it as a 2ndary AP. It will not be apart of the wifi mesh on the 50 series system.
