Kris222
May 30, 2018Aspirant
RBR50 / RBS50 - No Ethernet backhaul with new firmware
I have a set-up with a router and two satellites with ethernet backhaul.
After a satellite auto-updated to 2.1.4.10 my internet died.
Then I had to do a manual update on Router and other satellit...
Cmo1
May 31, 2018Apprentice
Same issue here. I had to make sure Daisy chain was turned on, or I get nothing. Hopefully yours may have been turned off.
- Kris222May 31, 2018AspirantThanks for the help. I’ll try - even tough they are not Daisy chained (star)
Best,- Cmo1May 31, 2018ApprenticeYes. Same here. I'm currently only using one wired satellite because my house is only 1700 square feet, but I still had to have that in or it did nothing.
Hi Again!
Daisy chain was on - Disabling it did not do the trick. Everything was fine with the last firmware. This is kind of a dealbreaker for me...
I can't get in touch with Netgear support - Does anybody know of a way??
Best, J
